Nomad2day
Longhair Redneck Geek
Out on the road yesterday and I start to down shift on a back road and started hearing a roaring noise from the primary case. The roar or whirl would be gear related. In second it would whirl one rpm and when I downshifted into 1st is would speed up with that gear. Took the bike home and did a couple of clutch adjustments to no avail. When the clutch is released no noise, pulled in a roaring noise. I had a clutch basket nut loosen up and the basket hit the primary last winter. Had the shop go through it then. Bunch of metal shavings came out as I sprayed the primary out tonight.
I got home tonight and take the bike out to warm it up and see how the last adjustment did. Still whirling but not as bad and hit and miss how loud when the clutch is pulled in. Got home and drained the oil and pulled the primary. Had a bunch of metal on the drain plug magnet. Pulled the throw out bearing which is binding and scarred up which probably is the culprit here. Had a bunch of scarring on the pressure plate where the clutch and diaphragm spring rides on it due to aluminum chips getting under it.
Pulled the friction plates out and checked them out. Some aluminum trash in the first couple of plates. No other damage that I can see. he clutch basket nut looks to be good and snug so I did not try to remove it. Took some CRC cleaner and sprayed out the back bearing through the carrier slots and had some more aluminum crap flow out.
I am going to replace the throw out bearing for the time being to see if it is in fact the noise maker for time being so I can get some road miles in. I will upgrade to the bandit system later next month if this goes well. I am going on vacation the second week on July to Florida to spend some time with my dad and let him spoil the grand kids.
Any other thoughts what would cause the noise when the clutch is pulled in or what I should check out while it is apart.
Guess I need to get a hold of WB Cycles and get a throw out bearing and retaining clip shipped to me quick....
