houseofcolors
Rear axel assembly
2003 Big Dog 107cc
Just purchased, previous owner said Rear Wheel bearing went out and he made repair.
Just replaced progressive shocks ,,Wild Steed Worx thanx those guys Rock.
I Removed rear tire to inspect …..
the one spacers against brake caliper support and rt. wheel baring wobbed out so I made a new one
Before I disassembled it the caliper support and spacers the axel bolt went thru were lose due to the axel nut tighten up on the axel Bolt shoulder not on the spacers, Barings, trailing arm,
Question: should the axel nut tighten up on the shoulder at the end of the threads leaving spacers lose about .125 or should the nut tighten up on the trailing arm, caliper support, spacers, and Barings if so at what torq spec.
2003 Big Dog 107cc
