Zoop Seal
Mach_1
I'm getting ready to apply Zoop seal to my wheels and other alluminum parts, anyone have any need to know advice?
Search Zoop and you'll find a lot on it. My 2 cents is nothing is going to work better than the other if you are putting miles on the bike and exposing it to the elements.
Mach_1
I agree with you Ray I was just hopping that this would help the shine last longer than a month or two, I hate the way the allum looks after a couple of rain storms.
Baldielox
I use wheel wax on my wheels and a few other parts after polishing. It helps the shine last longer, and less road grime and brake dust will stick between cleanings.
-B
jimizee028
TRUE COLORS COLLISION
gASMAN HAS WONDERFUL LUCK WITH THE PRODUCT AS YOU WILL SEE IF YOU search IT HE HAS A COMPLETE POSTING ACTUALLY SHOWING HIS WIFE DOING THE DIRTY PART AND HIM COMING BEHIND HER APPLYING THE zoop..........sorry bout the caps once again,anyway i didnt have that much luck cause as Gasman explains in his tutorial DONT ,WHATEVER YOU DO,PUT IT ON TOO THICK...............
bdmridgeback
Low Down Chop Shop
Just follow the instruction on the box just as they say. Don't rush and do not put more on than they say or it will take away from the shine.
The stuff works awesome, I did some polished wheels on my Impala.
The shit rocks.
Do like jake said. Follow the instructions.
Couple key points in order or doing
Rims need to be off the bike. I would also remove the rotors and pulley, they will just be in the way. The rotors are chrome and the pulley you can do seperately.
Polish better than you ever have!!!
When they say apply a small amount. What it should say is apply so little you dont think you put anything on. A few dabs on their towel they provide and rub on the rim. You will think you did nothing. HOWEVER, if you put it on what I believed as "small amount" it will be too much and you'll have to strip it, repolish and do it again.
If you do it correctly you should be able to follow up with the purple polisher stuff within about 10 mins. Anything longer than 20 mins and you probably put on too much. I'm sorry for you! Been there b4!
I posted tons of pics and shit about it in my Phoenix thread. Do a search for zoops by gas man.
