YES YES brother, I did, I did!!! These are my old ones, I have newer ones I'll be re-installing in my videos because I oversized......just wanted to try a new technique to get the damn carbon off........NOW, they actually look like they ONLY have 5k on them.....instead of looking like the have 30k on them...loldid ya scrape the carbon outa the ring grooves. Lookin good
What, exactly, is the new technique you used? that thing looks brand new!
Hold on, I'm changing wardrobe for my video...bwahahahaha.....What, exactly, is the new technique you used? that thing looks brand new!
SCRAPER???? You SCARE the shit outta me.....don't use a scraper or Brillo pads bro.....no need too.....I would start with a scraper then take an old ring and break it to clean the rings. Once you finish the scraping soak in a good degreaser and should be about there with a little buffing.PB blaster loosens most crud.
@Sven, please please chime in and tell us YOUR secret.....On sure someone will let the cat outa the bag "SVEN"
There it is...Good morning, Mr. Marky, Your mission, should you choose to accept it, involves dipping that sucker in pure vinegar and let it sit for a few days or when your finger can push carbon off, maybe 12hrs with that thin a coating. I recently hear someone set their valves in soapy water solution and would flake off the carbon. I also did vinny to the valves and they flaked off as well. So the next time I vin-douche me parts, I'm adding washing machine soap rather than dish washer just for testing the clothes chem reaction with vinny. So no harm no foul it might have a faster time on the thumb smear.
Your vid showing the results should have that disclaimer... 'No brillo pad or sandpaper sheet was harmed in this video.' Paper towel is about as rough as it gets. I push the remainder out of the piston grooves with the gunk spray> cutting that chemically. No need to pull rings off. So the cleaning sequence is vin-water-carb/gunk-brake clean-WD40-sits on a bench waiting for assembly. Or:
Vinegar: initial soak w/optional liquid type soap.
Water: to rinse or neutralize it.
Gunk: found the carb cleaner can around so, oh look pressure into the carb holes and goo came out.
Brake/Contact: this cleaner took the oil base of the gunk off the parts.
WD/ATF: spray or oil can w/thin oil, I want to soak the rings so no rust or acid is going to mess with the metals sitting for how long is one hour is too long.
That's also my MO too, is a one take wonder. It is what it is. There's no rule that says you can't edit and shorten the vids. You might like or have no time to edit, I don't care, keep them coming.
Great info Sven! And good job explaining it so we can all understand! Lol!Good morning, Mr. Marky, Your mission, should you choose to accept it, involves dipping that sucker in pure vinegar and let it sit for a few days or when your finger can push carbon off, maybe 12hrs with that thin a coating. I recently hear someone set their valves in soapy water solution and would flake off the carbon. I also did vinny to the valves and they flaked off as well. So the next time I vin-douche me parts, I'm adding washing machine soap rather than dish washer just for testing the clothes chem reaction with vinny. So no harm no foul it might have a faster time on the thumb smear.
That's some good info also Dan! Next time I blow a head or base gasket I am gonna definitely use that trick!You should see what soaking a piston in a coffee can full of Marvel Mystery oil will do,Diesel fuel works great too.....
Instead of octane booster, just run diesel in your bike and then the pistons won't get that carbon build up on themThat's some good info also Dan! Next time I blow a head or base gasket I am gonna definitely use that trick!![]()
Hmmm, not a bad idea, what ratio would you mix it??? 40:1?Instead of octane booster, just run diesel in your bike and then the pistons won't get that carbon build up on them![]()
That sounds like a chain saw mixture, so I would say yeahHmmm, not a bad idea, what ratio would you mix it??? 40:1?![]()
