WTB
07_r1
chrome exhaust that fits 05' Pitbull...looked everywhere but they are all for newer models...does anyone know other bikes that use the same pipes?
kmalysa
I have an 05 Pitbull I put the Vance and Hines big radius 2into2 on. I had to buy PN 26025 that fits '05 and up Bigdogs except the pitbull.
Same pipes just a different bracket. I made my own bracket based on the obsolete installation instructions for an '05 Pitbull (PN 26021) which I have attached a link.
It took me a couple hours and a few beers but it works. See figure1 in instructions in the attached link. I cut off the square part of the bracket that bolts to the pipes and welded it to a pc of 1/8" x3" bar I bought at Lowes. I bent the bar to the correct offset, trimmed, drilled and powdercoated it.
A little work, but just like you, I could not find pipes for my bike.
Ken
http://www.vanceandhines.com/download/D523IN.pdf
PS I will go out and take a photo and post soon
07_r1
thanks guys..nice work kmalysa...my biggest problem is finding a place with the big radius 2-2 in stock
07_r1
re
i finally found some...ordered the same part # u got...appreciate all your help and hopefully my bracket turns out that well...are they any problems with the passenger pegs?
kmalysa
That's Great!
No prob with passenger peg, they are well clear of that. To put the bends to offset the bracket you are going to make, you will need to heat it cherry red. I also bolted everything together and placed a welders clamp as well as make the location to weld, then removed and welded. Hope this helps?
Good Luck,
PS I used a pc of carboard and shaped and bent it first to use as a basic template.
07_r1
thanks man...you have been a big help...it already had an exhaust similar to short shots on it...I tore the carb down and it still have the 068 main jet in it so I was shocked...I'm going with the 072 main and 031 intermediate cause I have no other mods..sound right?
kmalysa
Glad I could help! V&H recommended an .076/.031, that s what I am running runs good, I later added the S&S Dual Runner intake, still running same jets seems okay. I want to get my bike Dyno tuned one of these days to be sure she is set up just right.
07_r1
bracket look familiar ? this is the only pic I have of it with the pipes on...get a better one out in the open 2m...ended up going with a 31 intermediate and a 72 main...runs crisp
07_r1
thanks..you were a big help...I'm going to start ordering stuff that does not fit my bike on purpose just so I can have fun fabricating
