WTB "G" manifold, 117ci 2005 Ridgeback
Does anybody know where I can get a "G" manifold for my 05 Ridgeback?
Also, I can't seem to find a support bracket for the carb, I was thinking about looking for a different type of filter assembly, other than stock, and might need one.
Check with Alhall, he may have one from his recent motor build.
Otherwise..
Order thru Nelson cause you have the taller cylinders and can't use the standard G intake.
Definitely order from big dog (Nelson) because if you are replacing your manifold you may as well get the 06 version to make up for removing of the restrictor plates.
