Wire plus sucks.....
drbalazo
Sorry for the vent. I've been having many problems with my wire plus. I replaced the ignition control module and the switch control module already and again, my switch control module failed one more time. Is there any other wiring kit out there that will free me from the problems I'm having?
Dakotabos
Feel your pain:bang:
If you still have your connector you might be able to get a PDM from Big Dog Parts King or someone else. Check and recheck your work. a Ground could cause issues or a bad splice or you may have gotten a lemon. Get a great Multimeter and check everything twice
My 2 cents
Good Luck
Jerry
Jerry
I used the PDM on my 2008 Mastiff and it was easy to install and has worked great. No cutting pretty much a plug and play. Of course a friend of mine who was a former Big dog mechanic installed mine. Does anyone know if BDM Performance is going to to be back in business? Hope all goes well.
pknowles
RETIRED
Not all of us have had ill effects with the wire plus. I'm thinking the ones that were built before Don left were the better ones. I have mine installed going on three years now and (knock on wood ) haven't had any problems with it. On another note, I just had Wild Steed Works check out my ehc that I had replaced and there was nothing wrong with it. Evidently, there was a grounding problem somewhere that I fixed while installing the Wire plus. Moral of the story, double check everything before changing out your ehc. Lessons learned the hard way usually last the longest. happy New year and good luck with your issues. :hi:
Jwooky
Feel your pain, I am on my 3rd. I am not impressed with them at all.
Just call them and try and get a competent answer about anything technical. They are clueless.
prairiehorse
My pdm works great. easy to install....sorry to hear about your frustration! :/
I do have another pdm brand new for sale. Check the swap-meet if you decide to look for new kit. Either way hope you get it back on the road
Nukeranger
Nukeranger
My Wire Plus has been working flawless. I just think sometimes you get a good one and sometimes not. My original EHC just went down hill to the point of frustrating and it tested just fine. I kept the original just to have it to swap with others when they have issues just to support troubleshooting.
chacha
Chaff Your EHC!!
four years on mine-no problems. I agree, I think the place went to shit when Don left.
