Wire Plus for EFI
chili08k9
I will buy the 1st round
hello all, I put this wire plus kit on my bike in 2012, had no problems till now. is there any replacement module out there for my bike? I really plan on doing a few nice rides and rally's this spring and summer. FYI i get lights on everything except the ignition legs. the fuelpump does not run when key turned on and no greenlight on module. 2008 K-9 EFI thanks in advance
Wires Plus is long gone. Somebody MAY have one on their shelf but that would it for WP. Hit up Curtis @ WSW on the Electronix Box. You will need the entire harnness as well. Or you may find a RIP kit out there. Wire harness as well tho..
Snuffy
I will say I have a 08 EFI K9 and Knothead fixed it. If you need an excellent wrench who is cheap he is your guy. Luckily you’re not all that far from him either. Just fyi if you need someone. Good luck
knothead
Second Chance Customs
I will look tomorrow but I think i may have rip kit efi harness for your bike...i probably got the thunderheart micro controller too which is the rip kit incase anyone wondered. Hopefully I do so it doesn't cost you 900.00 to get the new rip kit if you are interested in going that route
Jwooky
I agree with all, the WP is obsolete garbage and should be replaced, along with all the hacked up wiring it creates.
That said, there is only one power circuit that drives the fuel pump. I would jumper the EFI breaker with 12V to make sure that’s not the problem.
The pumps are notorious for getting contaminated.
chili08k9
fthank you
chili08k9
thank you
thank you
