trevor7042
Hi im new to the forum, my name is trevor, i work at an aftermarket harley davidson shop in ky, im working on a big dog that had a WP kit put on before me and then our former technician had worked on as well so im dealing with 2 different peoples messes, the bike was running fine then just died while riding, original issue was the power module caused the control module to go out(at least this is what WP tech told me), so i now have two new modules, when trying to start the compression release led turns red which according to WP indicates a ground, ive done an ohms test on compression releases they were fine according to S&S, ive tested the wires on the harness from point to point on the compression releases and do not indicate a ground, ive tested every wire on the harness and i am showing resistance on the horn wire, low beam. and high beam wires, im at a loss with this thing, any help would be highly appreciated
