Will they fit? (V&H Big radius compatibility)
wilycoyote
Ok.. maybe a newb question, and probably answered already, though I've looked and can't find solid info..
Got a line on a set of black ceramic V&H Big Radius pipes off of a 2010 street glide (right side final drive), for $250. Great deal right?
Question is, will they fit my 09 Coyote, and do so without major modifications to the bike or pipes..?
Appreciate the help, sorry if I'm missing something obvious here.
FrankBDPS
At 250 it will be a good deal if they fit. My experience with pipes that fit a Harley and trying to put them on a big dog has not been all that great. At the very least plan on making some brackets. Call Vance and Hines and see what they say about it. Good luck.
Marky-Marc
I have had good luck, but always did ALOT of research.....the main difference is going to be the bracket. Look at downloading install instructions from V&H site for the pipes your a buying, then look at the mounting brackets in the diagram the best you can......they are usually further forward. Most pipes CAN be made to fit with some modification...mostly the brackets...due to our frames/tires being WIDER than a harley.
You can probably have yours ceramicly blasted and painted black for around $250 as well, heat shields included...just a thought...I'm having a set done right now.
At $250, I'd buy them, see if I could make them fit, if NOT, resell them for $400... :D
