The 03 had a Thunder-heart controller and if you look on their site, is still avail. Add the fuses to it for the power lines and it should make the system more reliable. Like everybody said, it is has a lot of HD parts and you can basically get a repair part almost anyplace. You want a everyday bike, get the 03 because they are usually cheaper, and ride great. You can even put 422 shocks on itReason I ask is I heavily lean towards the 03 chopper.
I obviously prefer the K-9s 300 rear but the chopper has a slightly smaller wheelbase and will therefore be easier to handle and park. Also far less cost upfront.
However if I'm looking at an electrical cluster, the bike just wouldn't be useful to me since I commute daily.
Based on this and other things I've read on this forum, the 03 chopper is the last of the custom-build-using-Harley-parts line (in the same vein as Thunder Mountain and Titan where the bike is basically an arrangement of Harley parts or at least Harley fitment).The 03 had a Thunder-heart controller and if you look on their site, is still avail. Add the fuses to it for the power lines and it should make the system more reliable. Like everybody said, it is has a lot of HD parts and you can basically get a repair part almost anyplace.
The 03’s used an ehc and is not wired like a Harley “old school” type with a controller and relays . You are correct with the non proprietary parts as far as handlebars and controls .Based on this and other things I've read on this forum, the 03 chopper is the last of the custom-build-using-Harley-parts line (in the same vein as Thunder Mountain and Titan where the bike is basically an arrangement of Harley parts or at least Harley fitment).
04 was the first year BDM started doing their own proprietary electrical and other stuff.
Hence from a DIY perspective, the 03 Chopper is going to be the most straightforward to maintain and easiest to get parts for. Not necessarily the exact same part but a part with the same fitment, correct? Including electrical if it needs to be redone in part or in whole?
Check THIS out.I own a 2003 chopper with 43,000 miles, I also have a 2007 k9 with 9,000 miles . I have owned the chopper for years and put most of the miles on it. The k9 is a fairly recent acquisition. Both have been great bikes with very few problems and no electrical issues. I recommend big dog's to everyone I meet. I think the main reason I have not had electrical problems is that I live in the desert , not much water to get in electrical connections.
letting go of the left handgrip to use your arm to signal left is straightforward - how do you signal right?I have Zero turn signals
https://goo.gl/images/XmyAVSletting go of the left handgrip to use your arm to signal left is straightforward - how do you signal right?
