Where to buy spacers?
jkd740
Where can I or should I buy the spacers needed when I remove the restrictor plates on my '05 Chopper?
I'm going to be getting a XXX E carb and want to remove the restrictor plates at the same time. For those of you with the thunder jets mod, is it worth it? Most of my riding is longer trips cruising trips. I'm on the fence about weather to get it added or not.
Thanks!
jkd740
Just called BDM Tampa and they said I don't need spacers? Just new intake seals, is that true? From reading previous posts, everyone has mentioned spacers.
stlmikie
I wish I had more money.
Not sure about the spacers. But if you don't hotrod the bike and spend your time cruising I would save the money on the thunder jets.
jkd740
Called Fury this morning about the spacers and they said I just need the normal S&S gasket.
To clarify what I'm doing... Pulling my current E carb, removing restrictor plates, and putting on a xxx e carb. What do I need to put in place of those restrictor plates, if anything?
Thanks for the help.
