Where do I order parts from?
Jwooky
You either have to stay with BD and modules/computers or go old school. There is no in between. I bought a Badlands unit for my bike because I wanted the turn signals to work with old school wiring. If it quits I can still ride. The unit is set up for 12v functions like it's been for 60 years now.
I truly disagree with you. You seem like a sharp guy but you keep beating the get rid of computer go old school drum without fundamentally understanding or at least stating the difference. I feel this is very misleading to the layman. There are many ranges of in between.
What is a computer to you?, what is a controller?, what is a module? Are they microprocessor driven? What's good/bad? I would argue any of the above can be good or bad depending on the quality and execution.
The kits you are advocating still have a switching module?
Why is this in you opinion so much better than the Thunder heart?
The only real difference is you are advocating high current hand controls, which most would agree are very unapealing. The BDM controls are very nice trick custom units which I feel are an asset.
What I recommend, is to keep the custom BDM controls, and if an issue arises just replace the PC board. Low current switching is not the issue, it is well developed and reliable. I do agree the quality could be better of the boards and they should have been sealed/coated. I just don't think it warrants scraping the controls.
BadDawg Bill
We all have our opinions and no one is totally right or wrong. What ever floats your boat is the way to go. If you believe in the BD electronics and overlook all the "Help me" threads on here then good for you. I don't. That is my opinion.
Ok, I'll try to explain as not to confuse anyone. Old school to me is having just 1 starter relay that costs $12 and you can buy at any auto store. There is no "box, computer or module that translates signals from the handlebar switches to the starter, lights, horn etc. In my opinion these type systems break down because of heat, moisture, vibration and leave you on the side of the road. They are also very expensive. Get one lose connection or short and there goes your box and riding. Call the tow truck.
Old school uses 12v positive on switches to directly send the power to the bike and lights not some box. If your headlight doesn't work there is only 1 wire going to the switch on the bars so the wire is bad or the switch is bad. You can jump it to get home.
Old school doesn't use turn signals. I have never had them until this bike and I survived for 50 years riding using my hands. Right now my bike is hot wired to run with no ECH, module or computer in it. It has only 3 wires going from a 30 amp breaker and a 15 amp breaker that run the starter relay, lights, Ign and start button. (a cheap clip on button I have as a temp until I put on my new bars and controls, I also have a slam button
I could add relays for the turn signals, not too hard but with the Badlands box costing only $86 why not use that if you want or need turn signals? This will add more wires but if the box goes bad a simple jump from the positive breaker to the running lights will get you home. (the brake light switch is jumped from the running lights to begin with)
As I said "You either have to stay with BD and modules/computers or go old school. There is no in between." WP, RIP or any other "kit" using the "box" and BD switches is the same as BD to me. You are just swapping one problem for another.
You can't keep the good looking BD controls and switches and get rid of a box, module or computer. (well you could but you would wind up with a bunch of relays and it wouldn't make much of a difference)
Harley, Indian, Victory and many other bikes have used this system for over 90 years and it is simple and it works. In my opinion BD had a good idea in theory but bad in practice. Anytime you put a circuit board on a hot, wet vibrating bike you are asking for trouble.
If you want really nice old school controls there are many companies out there that make them but instead of $269 for a complete set they cost around $600. Arland Ness has a set that is killer.
And I do "fundamentally understand" the electronics because I have wired more bikes than you will ever own and I own a software company and build all of my computers.
JWScarab
I am VERY interested in this topic even tho its talked about a lot. But I do have JUST ONE question.....
Where did Willy Hank order his parts from??? :roll: :roll: :roll:
TapioK
WIRES PLUS in Winfield ks
Order direct it's cheaper
+1 (620) 221-2417
As I see it, anyone can order parts from where ever, but it is then only fair to ask tech help from them too, not from Curtis or Andrew, or…
I still remember this was at least one of the reasons Jake stopped selling Wires Plus and more or less disappeared from here…
Support our Vendors, they support You. Even if it’s slightly more expensive in the short run. :cheers:
