When i hook the battery everything lights up with key on or off why is this happening to me
Mikeinjersey
I've read some of your previous posts and it is a possibility that while you were trying to figure out where the wires go you may have actually smoked the EHC. Read this file and get familiar with EHC and how it works it may help you figure it out. The EHC has fault lights that may help you.
I gave you some instructions on Feb 14. Did you follow them ? What did you find ?
Ok so i figured out the ehc wires got a new battery and a multi meeter red that electric chapter you sent me hooked up the battery and still with key off or on speedo lights up No lights on the ehc no head light just right blinker lit solid like a marker no lights on the ignition mod no crank no taillights the speedo lights up with just the ehc wires to the battery i just dont know wĥy this is happening to me ì hauledthe bike from wa. To az. Thinking the wheather would motavate me and it did but i cant figure this out can i just get power to the ugnition mod and headlight and push button starter so i can ride does anybody have a stock ehc i can buy i dont have the money for a r.i.p kit please help me
Snuffy
These bikes are alot of things. Cheap is definitely not one one them. Sorry you’re having trouble. You should try and find a wrench close to you. Send your ech to Curtis and get it tested. The replacement he sells (axle) is great and not that expensive. I would suggest someone checking out your wiring also. Best of luck
If you have a good multi meter and a print of which pin comes from the key switch. You can disconnect the battery and then unplug the EHC check if that pin reads to ground. if it reads ground check the wiring.
So i pulled conecter b off tne ehc and pin 36 the power up pin is broken off so i guess that meens the ehc is toast does anybody have a ehc that i could buy for a reasonable price or should i just eliminate it and hard wire everything if so how do i wire the cr s to close after 1 sec
Mikeinjersey
