Wheel bearings help
If there is a seal covering the bearing, remove it. If you can see a bearing number, write it down. Then, type a search using 'cross reverence' + the bearing's number and brand.
Call a bearing house or order on line. If there is a website with cross references, you could update from said brand to timkin/japanese bearings. Something like that.
Try BCR bearings in Wichita. They are the original source for BDM. 316-265-0668
X-ray Doc
If it has the same as an 02, which I think it should, the front is a timken style (bearing
and seperate race) the # is LM11949, drag specialty #A251002 is a complete kit for the front. If the rear is still stock, it will be #6204-2rs 3/4"
