Thanks. Figured there had to be a simpler solution than what I was doing.If your wanting to pull the rear brake and mount you need to slide the axel out and drop the wheel then the bracket will slide out giving you room to either disconnect or pull apart the brakes then. This is what I do easier then trying to wrestle and twist everything and taking a chance of breaking or scratching the shit out of something.
