Whats going on here
Welderjeff
I'm new to working on motorcycles
I'm trying to change the oil in my 02 Pitbull and can't find the dipstick I've done some research and from what I understand it doesn't have one? Does anyone know if that's right? If so how the hell am I supposed to check the oil?
Any ideas on how I would be able to keep an eye on the oil level? I'm going to stick my endoscope down inside the Reservoir and see if there might be any markings
Once you change n refill, make a mental note of the level. Put a 2x4 under the kickstand to hold the bike level as you check the oil level. Scavenger will only pull out a small amount of oil. They work well and imo worth the $60.
Mickmorris
Well Known Member
When I first changed the oil on my Vintage Sport I recognized the same problem. I changed the oil & when I added the 3qts to the bag. I took a chopstick (wife is Japanese) and stuck it in to the bottom. It’s wooden so the oil gave me the needed level but I put a mark on it with a marker also. I use it to check the oil before every ride.
