I will check this too.You may also want to check the fuel cap and specifically the right one. Originally some had a Emission valve in them (it would ber white and screwed into the underside in the middle). If it is there, would recommend that you remove it for they have been known to create problems some times too. Basically if you fill up, if you have a tight cap, when it draws down, this POS valve may not act right and create a vacuum lock restricting the flow.
No need for it for 99% of us.
^^You may also want to check the fuel cap and specifically the right one. Originally some had a Emission valve in them (it would ber white and screwed into the underside in the middle). If it is there, would recommend that you remove it for they have been known to create problems some times too. Basically if you fill up, if you have a tight cap, when it draws down, this POS valve may not act right and create a vacuum lock restricting the flow.
No, I didn't hear the pressure release. But I just removed the white plastic part from the gas cap, and I am going to drain the tank, and clean the screen.yeah I was gonna suggest the gas cap - could you hear the pressure release when you took it off to fill up?
