What clutch are you running
  • Ball bearing lock up clutch
    Votes: 2 7.1%
  • Factory wet clutch
    Votes: 23 82.1%
  • Standard dry clutch with open primary
    Votes: 3 10.7%
  • Total voters
    28
  • Poll closed .
liferider
Looking forward to retirement
I have a BDL open primary with a ball bearing lock up clutch. Got a little getting use to but damn ! When it engages the harder the motor turns the harder this bitch bites.
Brew
-- Piranha Jr Klutch Pack open belt drive on my 2008 Mastiff
-- Bandit Bruiser wet clutch on my 2005 Ridgeback
Just finished putting an EFM clutch in my 06 K9 but I am still setting it up.
I got a killer deal on it used from a forum member, I'm sorry but my old ass can't remember who it was.
Just a slight drag so I have to pick up 6 more wave washers to finish the adjustment. Since I bought it used I didn't get the extra wave washers.
However the initial testing is making me drool to get out and run her. A wonderfully big side effect of the EFM auto clutch is the near zero clutch pull with my hydraulic clutch, I imagine due to how it operates a cable is the same way.
Tall Mike
Whatever came in the bike I'm guessing its the stocker..
Its got a heavy pull to it thats for sure..
Diesel Dan
After my stock clutch basket grenaded, I upgraded to the new Primo Pro Drag Clutch and basket setup,a little more $ than I wanted.........BUT when I got it,I knew why....the basket is HUGE and a forged 1 piece unit:eek:,clutch pack is massive.........installed it and adjusted clutch,serviced primary a few times to flush out any break in material,never had a problem since.........been like 2 years since that:2thumbs:...knock on wood
Bowhunter
Stock 'easy-pull' with absolutely no problems for 2 years, then switched to Baker Open Primary. I have had absolutely no problems with either clutch system, but the belt drive clutch is considerably harder to pull than the factory clutch.
