Whatever it is make sure you use the correct kind!!! Dot 5 is silicone based and does not mix with DOT 3/4 or DOT 4 brake fluids (which are glycol based). Also, make sure you let the brake fluid sit for at least an hour after you bring it home because silicon based fluids have tendency to aerate (think of a shaken up can of soda). It's also more corrosion prone, and doesn't give any visual cues to determine it's moisture content... basically that's a fancy way of saying you need to change it more often than glycol-based brake fluids.
