whatever01
I had a recall on the voltage regulator on my 06 Mastiff. When I took it to the shop they told me that if my regulator fell into a certain number range they would make the repair. Well it did fall under the units that needed replaced, but the dealer told me that BDM wasnt replacing the units anymore but were removing the circuit breaker and installing a fuse. What the fudge is that. Sounds like putting a band aid on a problem instead of making the proper repair. I couldnt believe that they wouldnt replace the recalled unit. They said if it went bad and blew the fuse they then would replace it. Like I have nothing better to do then go back in fourth to the dealer. If they recall something they need to make good on that recall not shoulda coulda woulda me around the block.
