Set meter to infinity:
1. Place black probe on engine case. Place red probe on one wire prong out of the stator.
a. Did the meter move, as if holding both probes in the air and not touching anything or each other. No. That's a good sign.
b. Did the meter swing to infinity as if touching both probes together as in checking the meter itself? Yes. That means the stator is short to ground and that is where whatever AC is grounding, not traveling up the wire to the V/R.
c. Did you test the other prong and read either a or b showing the answer?
2. Place black probe on prong, the other red probe on the other prong.
a. Did the meter swing as if touching both probes together? Yes. That's a good sign.
b. Are the male ends of the stator's connector green in color? Yes. That's a resistance problem.
c. If the stator test shows good, the male and female ends just might need new metal contact to send the AC up the wires to the V/R.
Well charged battery voltage:
1. Place meter to 20 DCV.
a. Place the black probe to any ground on the bike.
b. Place the red probe on the battery (+) side of the battery. Start bike.
c. Does the battery show static voltage, i.e., 12.8v and remains steady? Yes. Then it's the stator.
d. Does the battery show volts exceeding 15v? Yes. Then it's the V/R.
