I have only owned my dog for 4 months and all i hear from people is that i better get use to carring wrenches with me because things will always be vibrating lose. What are some things that tend to vibrate lose on dogs???????????????????
I lost a stash tube cap :bang:, Check the speedo bracket mine was loose one time.After that i just do a quick check on most visible stuff once a week while cleaning. :up:
you should do an inspection before you ride,some things that come loose are mirrors,turn signals,top motormounts,things like that,be safe and inspect also fluids,lights,tire pressures
I just replaced my ignition cover head mounting bolts with the longer 1 1/4" bolts coated with the blue Loctite because they were working loose. I also Loc-tighted the main upper motor mount with blue and re-torqued everything when I did it.
