Sellsbooze
Need help! I purchased a new set of Vance and Hine Big Radius 2 into 2 pipes today. I know I have seen a ton of bikes with these exact pipes and I seem to be having a few fittment issues. I have bolted up the pipes without shields and used the bracket that came with them (Harley Softail) to just attach the pipes to one another so I can figure a way to manipulate a bracket set up. My issues are that when the pipes, and bracket that attaches pipes to each other are tightened, there is basically no clearance at the rear next to the frame of the front pipe (bottom) when the heat shield is installed. Secondly there is no clearance between the front brake control and front pipe (at the bend). The will go on but will be touching? Lastly is there a stereotypical way of rigging a bracket or am I just winging it???
