V&H Big Radius 2 into 1 Exhaust
I have the V&H Big Radius 2 into 1 exhaust on my 08 Big Dog Ridgeback and I want to replace the stock baffle with an original Thunder Monster Baffle to make it louder. How do I remove the stock baffle from the exhaust? I appreciate everyone's help. :flag::flag::flag:
zipsman03
I have the same pipes, but haven't change out the baffles. but did on my last pipes, I went with the QQ quiet deals, there should be a couple of button screws to remove and she should come out with a little work.
aspen874
I have a set of new V&H 2-1 sitting in my basement, there are two screws that hold in the baffle. you will have to remove your heat shield and both screws, the baffle is in tight, I used a rubber mallet tapping on the pipe while pulling on the baffle at the same time, mine came rlght out.
Now that you have it out there are basically two three ways to modify your baffle, one includes the Big City Thunder baffle. If you care to PM me with your number, I will tell you what I have learned from Trainguy, Stroker and REMorris all of which have the same pipe
Do you still have these pipes? Can you send a picture. How much would you want? Will they fit my 06 ridgeback?
