Mastiff Rider64
As you may know my 06 Mastiff was stolen Sept 14th 2018. I just had a complete rebuild of the bike. New 124" S&S, new Baker Belt Drive. Well this means I have an 117" S&S with a .600 S&S cam disassembled motor. I have 4 S&S heads, 1 pair are the factory ones but the front head is has a egg shape hole where the valve seat is from it not being installed correcrtly so that head I've been told is just a paper weight even tho it is a complete head meaning all the internal parts, the other set are were fine but one of the valve seats were leaking. These heads were shaved down to create 10.5:1 compression ratio. I HAVE ALL THE PARTS for reassemble of the motor if you fix the head with the bad valve seat. Now it has been sitting in my building which is not climate controled all in boxes that the new motor came in. I'd suggest a rebuild on the motor just because its been disassembled since March of 2017. I also have a complete primary, inner plate, outter cover rear inspection cover has some chrome peeling, chain, tentisoner, gears and bolts also. I have a kerker 2:1 exhaust pipe non efi also, If any one is inerested in the whole set up package deal i'll sell everything for $3,500. You can either meet me to pick it up one weekend i'll drive up to 200 miles or you pay for shipping. Everything is already boxed up anyways.. If you want to see pictures look up my post: Stolen those pictures were before the rebuild.
I also have used factory grips, shifter peg, brake peg, front and rear pegs, shifter lever, brake lever, hand brake lever and hand clutch lever. I'll sell for $500 for all also.
