upgrade ignition
k-9 mike
I want to upgrade the ignition on my 06 K9 ,cam ,exhaust,xxx carb, live in Wyoming ride from 5500' to 11000' no air up here! Any suggestions on brands, dont want to change the timing cover!
R
Ridgeback Boy
Guest
I think 2 of the better ones from what I have read on here are the Thunder Heart and Dyna.
Remaining with the crank sensor you are then left with the Thunderheart or the S&S. I think I will be going with the Thunderheart also. I don't want to mess with a cam sensor.
:2thumbs: :cheers:
shovelcowboy
:2thumbs: :cheers:
Ray, do you have the thunderheart self programable and if so, has it been easy to use with your laptop?
Ken
Ken
No, I still have the stock unit but if I upgrade I think I will do the programmable Thunderheart since it would be pretty much a dirrect swap.
HDLarry did the S&S one and he's pretty happy with it.
You running a crank sensor on yours or the cam sensor type?
shovelcowboy
Cam sensor on my red custom, but the K-9 project 117 has the crank sensor (but no ignition at the moment). I may go the HD wiring way I did on the red chop since so far it seems trouble-free (It is the 107 with Crane Hi-4).
Ken
k-9 mike
Thanks for the input! Your the second person who has mentioned the Thunder Heart Programable Ignition. I have a friend with the Hi Crane 4 programable and he is very happy (on a 80ci Harley)
