shansel88
2004 chopper-
What voltage should I have when turn signal flashes??
Front turn signal is not working - running light is -
I tried switching bulb - left to right - bulbs are good
I tried to measure voltage - 12V to running light is correct
Voltage to flasher the must be too quick for meter to respond - can see meter switch from 0 to .5 or .6 volts as light flashes - but both sides seem to be the same? Maybe not exact but there is a response in the meter on both sides??
Any Ideas ?? Suggestions??
Thanks,
Sam
Thanks,
Sam
