1st thing the wp is not a bad setup just saying mine has lasted 2009 and have had no issues with it! Check your connections the down shift should have nothing to do with the wp system . Did u do anything else other than the wp install "like adjusting the clutch" etc???hi guys
just installed wp kit on 2008 mastiff efi.motor idles and accelerates fine,dies out on downshift.since the install the low fuel light stays on even with full tank of gas.any ideas would be greatly appreciated.
thanks NICK
PAUL1st thing the wp is not a bad setup just saying mine has lasted 2009 and have had no issues with it! Check your connections the down shift should have nothing to do with the wp system . Did u do anything else other than the wp install "like adjusting the clutch" etc???
Some people had problems with the Twisted spark-plugs.... do a search, several threads on this subject.PAUL
I would like to clarify that i have installed a plug n play wiring kit from dead one customs.I have added a set of twisted spark plug wires during the install and i did adjust the cluch.any ideas.thanks NICK
http://www.bigdogbiker.com/threads/what-plug-wires-are-you-using.73857/#post-685881Some people had problems with the Twisted spark-plugs.... do a search, several threads on this subject.
thanks FRANCO,I'll check that out.Some people had problems with the Twisted spark-plugs.... do a search, several threads on this subject.
So when you down shift do you get kind of a clunk and the it stalls? More than likely your clutch is not adjusted correctly.PAUL
Agree,Put your original plug wires back on and see if the issue is still there. If it's not then you know the twisted wires may have caused the issue.
OK..... here ya go.... your stating trouble with a wp kit.... Now your stating you've installed an ESC from DOC?PAUL
I tried stock plug wires,same thing happened.I am certain that I have an esc from docs.the reason I posted on here was I was hoping to get a fix for the weekend.I have sent a message to docs and wil see what they have to say.I would like to thank yall for responding to my questions.Have you tried yet?
Ok so it's not a wire plus! I was looking a schematics for the fuel issue. I am not familiar with the plug and play but electrical issues are usually bad or loose connections. I guarantee you the down shift issue is due to your clutch not being adjusted right.I tried stock plug wires,same thing happened.I am certain that I have an esc from docs.the reason I posted on here was I was hoping to get a fix for the weekend.I have sent a message to docs and wil see what they have to say.I would like to thank yall for responding to my questions.
Now I see why your avatar defines you!OK..... here ya go.... your stating trouble with a wp kit.... Now your stating you've installed an ESC from DOC?
I think you don't even know what you've got in there? Get your facts right: Is it an ESC or a WP?
If its an ESC, why don't you contact DOC???
lol, sometimes yes... but I didn't meant it to come across that way!Now I see why your avatar defines you!
I have the same issue with my wife. It frustrates me and surprises me the way she perceives me despite my explanation of what I meant! It makes me just want to shut up and not say anything. The one that gets me the most is "You're mean to me"! Very disturbing because I certainly don't try to or go out of my way to be mean. Maybe, I am mean to others and don't know it. Maybe, she's bipolar. Everyone else in her family is!lol, sometimes yes... but I didn't meant it to come across that way!![]()
What! You have been listening me and my wife?I have the same issue with my wife. It frustrates me and surprises me the way she perceives me despite my explanation of what I meant! It makes me just want to shut up and not say anything. The one that gets me the most is "You're mean to me"! Very disturbing because I certainly don't try to or go out of my way to be mean. Maybe, I am mean to others and don't know it. Maybe, she's bipolar. Everyone else in her family is!![]()
