TRANSMISSION OFF TO ANDREW
nobbyjohn
Well the clutch problem i thought i had turned out to be a broken trans shaft.Finally got it out and shipped.Don't want to do this again so if there is anything i should replace or check or grease or shine, seriously anything you guys can think of cause i really don't want to do this ever again.Bike only has 8300 miles.
since it is down, might as well go ahead and break into the starter and clean up the contacts if they need it and maybe a slam button. replace the seal between the starter and the primary for good measure.
just my thoughts for what they are worth.
nobbyjohn
Thanks i will start on that in the morning, is that seal available thru BDPP? Sombody mentioned in an earlier post when i thought it was my clutch that they made a clutch cable that. was beefed up any idea who that might be.
If your starter is floaded send it to us. We'll seal up all the drain holes that are in it, seal it up tight after we completely disassemble it. Then electrical check it rebuild it better than it was. All for $99.
Www.wildsteedworx.com
Sent from my DROID RAZR using Tapatalk 2
