Transmission leak
nobbyjohn
Prob the race has walked causing oil to get past seal. I have this problem myself on my vintage pro stock. Really pisses me off since I set it to tolerances , 001, and started leaking after a thousand miles or so of replacing shift pawl. Even called BD and asked about it when was putting back together. Found out o a site thru Baker. They sure won't tell you shit, but look up and read about it. That race will move. It never says how to fix it, so I assume it's just replace with new and repress it back on. You do have to order a tool to pull and replace. Not much tho. I think on Amazon for less than $45.
Sent from my Pixel 3 XL using Tapatalk
So sick of the oil all over my rear wheel and well just about everything south of the transmission I put 10 ounces of lucas engine oil stop leak and 10 ozs of Red line hasn’t leaked a drop in 400 hundred miles.
PHATASS
Curious how the leak has held up? I have the same issue, again and been through all seals twice. Quits leaking for a few hundred miles and starts again. Thanks
Marky-Marc
reviving an old thread cool...not to be an ASS but, are we SURE it actually IS TRANS fluid (sorry, have to ask because I didn't in 2019)? If it is, I'm assuming everyone is checking their trans fluid and having to refill it? yes? Just curious....and I'm still saying you should put a DYE kit in it.....ride it...and follow the leak.....
nobbyjohn
Had the same problem with my trans leaking , last resort 10 oz lucas trans leak and 10 atrans fluid about 10 dollars ,rear wheel is still dry!
rpols7
How is your primary oil? I have seen it numerous times where the main shaft bearing is sloppy and it sucks the primary into the trans.
MASTIF 2006
Spacer Wear: This is by far the most common cause. The spacer between the gearbox and the pulley wears out. Once a groove develops, the O-ring no longer seals, and oil floods the drive belt and pulley.
Bearing race walk: In these gearboxes, the raceway can shift slightly on the shaft under load. This causes immediate seal failure and oil leakage.
Using oils that are too thick (e.g. the popular Red Line Heavy ShockProof) in these specific designs means the oil cannot lubricate the tightly fitted small bearing, leading to it overheating and melting.
I recommend using dedicated, thinner gear oils, e.g. Lucas V-Twin Gear Oil 75W140, which dissipate heat better
