Touch Up Paint
Alicat
Hanging out
Ok spring is here and I'm back in Michigan and decided to try the touch up paint I ordered from Big Dog.
It came with 3 bottles, Black, Clear and Hardener.
My question is after I use the black do I put on the hardener or the clear?
Al
slowrower
2007 Mastiff
I think your supposed to mix the hardener with the black and clear -- most paints today require a hardener and if spraying you also need to add thinner. There should have been directions for how much hardener to add, if not contact BDM as the mix ratios can vary between brands. Good Luck and get that dog looking like new!
V
As usual Gas is correct. Mix the paint and the hardener. Allow to set and the carriers to evaporate then cover with clear:cheers:
V
V
As I have told you many times bud. Even a broke clock is right twice a day. :D
