anyone know front rotor torque specs ?
My manual states "Brake Rotor mounting bolt torque" 50 ft lbs (torque in a star pattern). In the illistratoin is states to work up to 50 ft lbs by first torquing to 40 then proceeding to 50 using a 5 pt star pattern.anyone know front rotor torque specs ?
Thats crazy how my manual says something completely different than your Ray. I can't believe there is that much difference from 04 to 05. Crazy.My manual states "Brake Rotor mounting bolt torque" 50 ft lbs (torque in a star pattern). In the illistratoin is states to work up to 50 ft lbs by first torquing to 40 then proceeding to 50 using a 5 pt star pattern.
Brake caliper mounting bolts 25 ft lbs.
If you removed the wheel then;
Front axle 45 ft lbs
Front axle pinch bolts 12 ft lbs
Hey Ray,My manual states "Brake Rotor mounting bolt torque" 50 ft lbs (torque in a star pattern). In the illistratoin is states to work up to 50 ft lbs by first torquing to 40 then proceeding to 50 using a 5 pt star pattern.
Well I have REV A of the 05 manual and I'm looking at it right now on page 10-2 and it states;Hey Ray,
I believe the torques you are referring to are the wheel hub bolt torques and not the rotor torques.:zz2cents:
