I changed the ignition to an Ultma Single Fire. When you ground the VOES wire you have full advanve
at 1500 RPM makes it much easier with the "site" glass. You pull the timing to the left of the hole
using a dial back timing light. I have a Snap-on that worked great. Timing is at 30*
