Thunder heart programming ?
zipsman03
So I get the thunder heart for the pinging issue. I am running stock pipes, 600 cam w/640springs decked cylinders 92 octane is all I can get 31 and 78 on the jets. I played with the setting still haven't found peace yet. So I call S&S to see where I should have the custom settings, Wolf Tells me 18 degrees at idle 1000 RPM's and 32 degrees at 3500 RPM's. When I look at the chart, setting 6 starts at 15 degrees and flattens out at 37 degrees but at 4100Rpm's.:confused: Should my custom curve flatten out at 3500Rpm's or continue up to 3700, but having the idle start at 18 degrees:confused::confused::loony: pt 2 how much less should the rear advance be, according to section 2.3 for those who have the manual, than the front? I hope this is clear enough for you, cause its mud for me right now.
