Those should be the correct cables if that's what they have listed. The only issue you may have is that I've seen some big dogs with the tall cable guide on the carb. This guide is for cv style harley cables. Either this was changed by a previous owner or the company ran short of s&s cables occasionally and used cv cables. Check your cable guide to see which one you have. If you have the short one, then the cables they have listed should be correct.
Also, I forgot to mention, does it still have an s&s carb on it? If someone installed a mikuni, they only use cv cables and can't be adapted to s&s cables.
