BDCU
Hey Guys, I just joined the forum and I need some help.
I recently purchased a Dog, a 2007 Mastiff and apparently inherited someone else electrical/mechanical problems. I’ve followed a couple of other postings on here of similar topics, but none have exactly the same symptoms, so before I shell out a few hundred dollars for a new starter I want to make sure I’ve eliminated any other possibilities.
When I try to start it, all I get is a single click sound, which I believe is the solenoid. Here is what I’ve done so far:
So I’ve come to the conclusion that, even though the starter looks good, it must be faulty since it doesn’t turn/engage. Does this seem like the right conclusion?
Thanks, your input will be greatly appreciated!
- The battery is brand new and fully charged
- I’ve taken the starter out and, while the pinion gear doesn’t turn extremely easy because of the pressure from the brushes, it easily protracts and retracts, bearings spin freely, and overall, isn’t very dirty and has no seized parts, but I still cleaned it
- All the connections to the battery, solenoid and starter have been cleaned with emery cloth and tightened securely
- I’ve taken the steps outlined by DRBarnhart for testing the solenoid which seems to be working fine
- All the lights, including the speedo operate
- The volt reading on the battery is 12.7, and during the time when I press the start button, drops to 11.8 v at the solenoid which is acceptable
