The Annunciaor
Guillaume
Maybe sombody can help me out ,When I go to my first gear the Annuciator let me see 1 gear and also the second gear but the other gears don,t show is that normal or you have to see the rest of the gears too.
K9 2007:(
Guillaume
Hi Pknowles
Well if I put the bike in first gear then it flassing 1 and when I put the bike in 2 gear it flaasing 2 but if the third or fourt , I dont see the numbers flassing is that normal .
pknowles
RETIRED
I don't think this is normal. Is your neutral light working?if it's your tachometer not working, check the connections coming from the tach going under the tank. Some on here have had the wires break on the ring itself. I have a spare tack if you need it.
BigDogBro1
Made in the USA
There is NOT a gear indicator sensor in ANY Bigdog motorcycle, only NEUTRAL.
You need to more clearly describe the effect and by which indicator you see it on.
The outer RPM tach ring will only show current engine RPM. If it's flashing, either your engine idle is set too low or you have other problem.
francoblay1
The Spaniard
:iagree: Adjust the Idle.
Guillaume
If I start the bike the light are moving around in the outside ring, Now if I put the bike in first gear a number come in the ring nr 1 if I put hime in his second gear the nr 2 coming on ,I have no gleu if that is normal or there is something wrong ,I check my connectorunder the feul tank .:rolleyes:
Thanks guy,s for the reply .
Marky-Marc
When you start the bike, the light around the ring is a self check and is normal.
When you are switching gears from 1 to 2 are you driving or are you just idling and switching gears?
If you are idling and just switching gears, do what franco says and adjust the idle.....
there is no gear indicator on any BD speedometer....
