Newcityboy22
I am having the infamous problem of not finding neutral:bang::bang: I have done the adjustment 5 times with no luck and figured my disks might be warped so after tearing it down for the first time since I bought it I found that it has a easy pull currently installed in it and no aftermarket goodies. After breaking out the glass I found that 1 of the 9 plates was warped and that it probably has the easy pull ball and ramp.(can't find much time to work on it. Bought a foreclosed fucked up house to say the least) so question one is what is the difference between the easy pull ball and ramp and the original 12 plate ball and ramp? Question two is since I want to do a bandit switch out and I'm tight on money now and I'm going to need a 12 plate ball and ramp to do the switch, do you think I could luck out and switch those and get by for now? Question three is who has a 12 plate set up that there not using to try it out lol?
