super G
T.Byrd
Does anyone have any suggestions where one might find a nipple to
screw into the vent hole on the bottom of s&s carb.I would like to run a hose from it to keep it from discoloring the carb.
chacha
Chaff Your EHC!!
T. Byrd - are you possibly talking about the bowl overflow vent? If so, you do not want to cap it off. It should have a line running from it to under the bike. Oddly, the fuel line used for model car racing and aquarium air pumps will fit, so you can pick those up at a hobby shop or a pet store if you're far from a MC shop....
T.Byrd
No I'm talking about the plug in the bottom of the vent hole at the far left
side of the carb.When you are running a volicity stack or a breather
system that has no filter system you are supposed to pull this plug.I was just wandering if anyone might know where one could find a nipple to fit where
the plug was.
T, see if it's the same size theads as the float drain fitting and if so just order another of one like it from S&S. I'll be its the same size!
T.Byrd
Ray im at work right now, but i'll look when I get home I did look at that eailer
and it looked like the one on the float drain did not screw out.
