2004 Boxer,Need help with starter stays on after bike starts. Key will shut off engine but starter keeps cranking until you pull crank wire off starter. Only stays on once every 10-20 starts.
Welcome to the lb, post an intro when you have time. Sounds like a stuck starter selenoid. Do a search on stuck starter and you will find what you need to clean up the contacts..
