Moespeeds Well-Known Member Dec 23, 2008 #1 Hey guys, I'm pretty sure I asked this last year, but couldn't find it when I searched. What's the stock NECK rake on my '04 Chopper? I'm thinking 39 but can't remember! Forget the trees, just the rake in the neck is what I need. Thanks!
BroadBand Since late 60's Dec 23, 2008 #3 Quick cut & paste From the 2004 OWNER’S MANUAL Chopper warranty: 2-year factory warranty transmission: 6 speed rear suspension: hidden shocks dry weight: 635 lbs. primary drive: chain front brake: PM 4-piston caliper engine: OHV 45 degree V-Twin final drive: belt rear brake: PM 4-piston caliper displacement: 107 cubic inch frame: solid mount front tire: MH90 x 21 rear tire: 250/40 x 18 bore and stroke: 4 x 4.25 inch seat height: 25 inch compression ratio: 9.6 : 1 ground clearance: 4.75 inch ignition: electronic fuel system: S&S Super G carburetor frame rake: 36 degrees charging output: 32 amps fuel capacity: 4.25 gal. (one-piece tank) wheel base: 78.25 inch battery: 270 cca oil capacity: 3 qts. front suspension: 41 mm telescopic tire pressure: front-40 psi/rear-42 psi *option: 117 cubic inch S&S engine / bore and stroke: 4.125 X4.375
Slinger2 Active Member Dec 23, 2008 #4 That's funny Alhall and I were just talking about that. 40 total including trees. I believe. 36 on frame 4 in the tree. :2thumbs:
