Still Some Problems running
shansel88
All,
I am still having issues getting my bike running properly.
Initial diagnosis-
Bike ran great - occasionally blip at highway speeds
Started to cut cut more -
Cleaned are filter
Replaced spark plugs
Rebuilt Carb 2 times
Adjusted A/F just trying anything.
Currently - same issue
Bike runs fine around town - less then 1/2 throttle
Occasionally will run good to full throttle
But more then ever its starts sputtering/coughing?etc at 1/2 throttle or during acceleration
Axel Computer-
Has Ulitma 53-644 ignition
I tested coil - 3.2 volts everywhere - 13.2 on high side.
Now i has 12 volts to one cylinder even though ignition not on??
Also, - I have no status lights to the ignition - no LED blink during power or even when running?? And no Voles??
My question is where do I go next logically?
Are those coil reading good?
Should I replace ignition since no Status light indication even though it sparks because bike does run?
Do replace cam pick up sensor - is this why I see no LED status (but I dint even see check at power up)
I am thinking of replacing all
ignition, coil, cam pick up sensor???
Do any of these make logical sense for why running sometimes and not others and especially most impacted at 1/2 throttle?
Any insight would be greatly appreciated - I want to try all I can before taking to shop for them to say they cant make it happen or charge me for ???????
