HuskerChop
This is good cr, front, actuated, very short travel and cut down part of shaft allows compression to pass thru plunger seat, thru inside of cr and exit thru holes
The poster and Sven are obviously better mechanics than I am. But I figured I'd throw this out to make sure you thought of it. Not sure what bike you got didn't see it posted I'm guessing its +05 since its a crank sensor? That should be a single fire coil and ignition box. Shouldn't fire on both strokes.I see what you are talking about. I am new to the V twin thing and forget about the cylinder being sparked during the power or exhaust stroke. Lesson learned,thanks.
Now another stupid question, I therory shouldn't the engine stop with one cylinder close to the top of the compression stroke? Of course I realize that the compression could be lost between starts.
I used to have trucks with 2 stroke detroit diesels in them. They were know to roll over and start running backwards especially on cold mornings with weak batteries and a good snort of starting fluid.
And yet another lesson learned. Thanks for the info.The poster and Sven are obviously better mechanics than I am. But I figured I'd throw this out to make sure you thought of it. Not sure what bike you got didn't see it posted I'm guessing its +05 since its a crank sensor? That should be a single fire coil and ignition box. Shouldn't fire on both strokes.
That does happen on EVOs with single fire coils and ign boxes and that is stock on 04 and earlier BDM.
Just wondering If you got a mismatch between coil and ign box causing issues.
I had a typo last night 2004 and earlier had DUAL fire coils and DUAL fire ignition. I incorrectly said single. I've edited my post.And yet another lesson learned. Thanks for the info.
