toadstool
While attempting to start my 2008 mutt the starter kept engaging despite letting off the start button. I turned the ignition off and the starter continued to engage over and over. Then the battery boiled. I self-diagnosed a bad solenoid and the local Harley dealership bench tested the starter and said everything was fine. I had them install a slam button I purchased from a site vendor. The slam button is hard to push and doesn’t make a good connection. To get the starter to engage the slam button literally has to be smacked using a block of wood and a hammer. The bike worked fine for a week and did the same exact thing with the starter sticking and the new battery boiled. A local independent shop installed a new starter relay and said they started the bike 20 times without an issue, problem solved according to them. The bike worked fine for a while then today the same thing happened again. Any ideas?
