STARTER.. Confused Need Help
KJW
I have a 03 chopper I was having start problems traced
it to a basd selnoid which i rebuilt I also installed a plunger start button
got it all back together..when i turn the key the speedo jumps and all
lights work it will start with the plunger but not the start switch
so I traced it to what I thought was a bad relay module which i ordered
took 8 weeks to get... just got done installing it...key on.. speedo junps all lights work when I press start head light goes out and the red light in relay
goes on....nothing but a click...bike starts with plunger ..runs great
ever thing works fine once running....thinking of doing the wireplus thing
just was hoping it was something more simple....any help would be great
KJW
put a new battery in same results...when i press the start switch ..
lights go dim ...both the red and amber light up on the start relay..
acts like a short .....not sure where to start looking......
:confused::confused:
Coolbreeze
Check the voltage at the green trigger wire at the starter. You should have 12v. Make sure your ground is tight at the batt. and the other end. Usually the other end is at the starter mounting bolt.
Coolbreeze
The headlight may go out when you hit the starter button. designed that way. does it come back on when you let off the button?
KJW
yes lights come back on ..I will check the ground at the starter...
had enough for one day will start checking things again in the morning
thanks for your help.....
KJW
Is it possible that the soleniod is bad inside?...I have replaced the
five prong relay
I have a new battery
new ignition start module
rebuilt the soleniod contact points
can you get them rebuilt or am I looking at a new starter
Donald
Had the same problem with my bike, 06 ridgeback with 117 S&S. Ended up that I had to replace the battery because the old one had a dead cell! Was told the make sure all the power in the ECI(think thats what its called, box in front of battery with the red light) was gone. Put new battery in and everything works perfect now.. I couldnt even jump start it.. crazy but had to reset that ECI.. Hope that fixes ur problem if not that may need to be replaced. If the starter works with the plunger its not the starter
BigDogBro1
Made in the USA
It could be the solenoid.
All battery connections clean and tight.
Is the click...click a relay or the starter solenoid kicking in?
Are you getting 12 volts at the solenoid when the handlebar starter button is held down to start?
Take a 12 gauge jumper wire and try to jump from the battery (+) terminal to the solenoid wire connector (with the original solenoid wire disconnected). See if the solenoid kicks in and the starter engages (TRANS in neutral) and the engine spins over. This will bypas all other electronics, switches, relays etc..
If this works, it will verify good solenoid windings, contacts and internal mechanism.
If not, it could be a funked solenoid.
You can go from there....
Good hunting.
moeszyslak
i have the same issue with my 03 chopper, and i also have the plunger starter button. i dont think it is a battery issue because i rode most of last summer without ever getting stranded and i didnt ever use a battery tender. when i push the start but nothing happens, no click, no noises at all. i have power to the starter when i push the start button but nothing happens. i have been told there is a wire inside the starter that can break due to vibrations. i still need to pull my starter before summer to check things out.
KJW
sounds like my problem so did you rebuild the starter
or buy a new one ..I'm not ever sure what model my starter is?
I know it is a Sypke not sure which one ...not sure how to find out
which model it is ...any help here would be great
