bigdawgj919
Hey Ok so I added a pair of 2" 50watt spotlights from Headwinds. worked at first then the fuse popped and continues to do so. lights are wired directly to battery with a circuit fuse inline and using a HD waterproof accessory button switch mounted in hole drilled into the coil cover. still running EHC. is there a built in accessory wiring harness I could use or is it best to run as is?
