ChopperJeff
A few days ago during a ride my tach and bright light indicator LEDs all started going nuts, with them flickering on and off, going bright, then dim, etc. It was like watching a light show! However, my speedo and odometer all worked fine.
But then yesterday I start the bike, and there are NO LEDs lit, AND neither the speedo or the odometer function! In fact, even pressing the little rubber button thing to switch from odometer to trip meter mode does not function.
I then hit the kill switch, turn the key off, then back on, allow the speedo to run thru its diag routine, then press the rubber button thingy and lo-and-behold it changes to the trip meter mode as expected. I'm thinking "Oh, must be OK now", so I proceed to start the bike. After starting the bike, the odometer/trip button doesn't work any more, and sure enough, the speedo and odometer are not working.
I then shut it all off, restart, and all is fine... except for the tach which still thinks it's a set of Christmas tree lights flickering and flashing all over the place.
This morning though I could not get the damn thing to work at all even after about six tries.
I guess I'll yank the tank and check the connections and such, but has anyone else gone thru this?
I had the speedo recall done about 6 or 9 months ago and all was working well after that.
If wires/connectors all check out, maybe I should just order a new speedo/tach and replace the silly thing, and hope that's it. :bang:
