KLRDOG Active Member Sep 19, 2013 #1 Anyone ever have the case of the speedo separate and not stay together? Is there a rubber washer or ??
KaptinAmerika Guru Sep 19, 2013 #2 There is a screw that holds it in at the bottom of the speedo case. The nut that the screw threads into is tac welded to a frame. I have seen that nut separate from the tac weld which allows the case to come loose.
KLRDOG Active Member Sep 19, 2013 #4 hmm I see no screw towards the front of the case where it seperates.
