That looks great is the speed accurate any problems
Well others on here have done it without problems. There is two different cases. You see in my thread I have a plastic case that is glued shut. When I got it all back together it didn't read properly!
But, I did it the night before I attempted my Smoke Out ride a few days ago when I ran into snow. Since then the bike has sat in the garage and I haven't checked it out but think I may have not got one of the connectors tight. I need to pull it apart again and check the wiring. I worked but wasn't reading properly.
Should be no problem once I pull it out again.
As I stated above it's not an easy mod but is complicated and you won't get it replaced by BDM if you attempt it. But others here have done it without porblem so I'm confident mine is a wire issue that I caused.
Could have been the speedo is going haywire looking at my new picture!!!
